3/8 or 1/2 inch ply?
Discussion in 'Wooden Boat Building and Restoration' started by robertgrandbois, Apr 1, 2010.
  1. robertgrandbois
    robertgrandbois Junior Member
    I am restoring an old plywood boat. The frame is all red oak and in very decent shape. There was 3/8 plywood on it before, but I can get 1/2 inch on sale at half price but I am scared it will not bend at the bow. Can I do the bow with two layers of 1/4 and the rest with 1/2 inch?
  2. alan white
    alan white Senior Member
    You're right to be worried. The thicker plywood isn't just 50% stiffer. It's probably about twice as stiff as the 3/8. Unfortunately, short of running the finished piece through a drum sander to make it thinner, you'll have to bite the bullet and buy the more expensive plywood.
    You could, as you mentioned, use two layers of 1/4" plywood, but you will use a lot of epoxy becuae the whole piece ought to be 1/4", or else you'll have to scarf it in, which is a lot of bother, to say the least.
  3. robertgrandbois
    that is what i tought but was hoping to save a few bucks. i will go with the 3/8 plywood. Now could i use the 1/2 inch for the top? it does not seem to have much curves to it.
  4. alan white
    Yes, of course, at the cost of some extra weight.
  5. tom28571
    tom28571 Senior Member
    You can scarf a piece of 3/8 to the 1/2 for the bow section. Works fine and this method is used by many.
  6. robertgrandbois
    ok tom i but i was thinking of doing a but joint would that work?
  7. lewisboats
    Likes: 128, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    no...the transition needs to be as strong as possible. To use a butt block you need to have the same thickness to butt together. That option really needs a 12:1 scarf.
  8. alan white
    That's true. It would work fine and would be practical if a scarf was required anyway to lengthen the panel. If not, buy the 3/8" plywood and save the hassle.
  9. robertgrandbois
    I got the ok to get all 3/8 from upper management(wife). There originally was a scarf but I was thinking of a butt joint instead be faster.
  10. alan white
    A butt located where there's not much curve or twist, with a backing plate, is not a problem. Especially if the exterior will be glassed.
  11. ancient kayaker
    Material stiffness varies as the cube of thickness. 4/8 thick ply compared to 3/8 ply would be stiffer by a factor of (4/3)^3 = 2.37
    Thats assuming uniform material. However if the ply has relatively few, thick veneers, it would be more flexible in one direction, so perhaps you could use it "cross-grained" and still get around the bends.
  1. Bill57
  2. rasorinc
  3. missinginaction
  4. Unkorahj
  5. johnnythefish
  6. Brentmctigue
  7. Sunburned One
  8. sdowney717
  9. Travis Grauel
  10. Paul D
