2x40 or 1x 80hp
Discussion in 'Propulsion' started by Matt.D, May 8, 2008.
  1. Matt.D
    Likes: 1, Points: 0, Legacy Rep: 6
    Matt.D Junior Member
    Can anyone tell me will mounting tow 40hp outboards side by side (on a house boat 2x pontoons) give me the same thrust and top speed as one 80hp outboard? and is there any limit to how close u can mount 2 outboards togather?
    Thanks Matt
  2. Manie B
    Likes: 117, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    My experience has been 2 motors is better "bite" for taking off, but less top speed = more drag.
    Not too close together that you cant work on them with ease.
  3. Pericles
    Likes: 135, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
    The wider the spacing between the motors, the easier the manoeuvring, especially on a pontoon boat.
  4. kengrome
    Likes: 25, Points: 0, Legacy Rep: 305
    kengrome Senior Member
    I've been told that two small engines never equals the power of one large engine rated at the same total HP. In fact, one guy told me you're lucky to get 50% more from the second engine. Nevertheless, having two 40's does give you a backup engine even if they only produce the same as one 60 HP engine.
  5. northerncat
    Likes: 1, Points: 0, Legacy Rep: 9
    northerncat Senior Member
    ive heard that you get 80 percent of what a single motor would give you
    sean
  6. Pericles
  7. Fanie
    Fanie Fanie
    I agree with Kenneth and Northerncat. Two 60's won't give the same performance as a 115. I've had 2 x 60's on my previous boat which is the same boat I now have with one 115. The 115 with a high pitch prop performs about the same as the two 60's on bringing the boat on the plain, after that the 60's are left behing very quickly.
    If the 115's prop pitch is to be dropped to a 17 or an even more radical 15 pitch for high torque, the 60's won't even come close.
    The idea to use two motors instead of one is only for safety - if your one motor fails you can still get home and not drift off with the current and when you hear 'clonk !' you say is this the Nort Pole or South Pole.
    This could be significant since Father Christmas is at the North Pole (I saw this movie once...). Besides .AU and .NZ I doubt there's very little else at the South Pole :rolleyes:
  8. masalai
    masalai masalai
    Fanie don't forget SA and SA... (your place and further west) there is nothing between SA and Antarctica except a bit more distance to get wrecked by the winds and seas...
  9. RHP
    Likes: 85, Points: 28, Legacy Rep: 1183
    RHP Senior Member
    Hence in SA all motorboats have to have twin engines (as I was told in January whilst on holiday).
    Gorgeous great big Yamaha twin 225's etc...
  10. Fanie
    Fanie Fanie
    Only if you go out at sea. Inland waters you don't even have to have a motor at all :D but most guys fit one... ;)
    Masalai, they claim the 'earth' was once one continent that ceacked up and the parts drifted away from one another.
    Now they claim the opposite is happening, the continents are drifting back towards one another. I wonder that the US is going to do when the philamons start robbing and plundering across the channel...
  11. masalai
    masalai masalai
    rob back as they will be poor then too....
