2D to 3D, possible?
Discussion in 'Boat Design' started by Andrea Gail, Mar 9, 2004.
  1. Andrea Gail
    Andrea Gail Junior Member
    In Autocad 2002
    Is it possible to transfer a 2D print into 3D :confused: ?
    If you got all of the views....
    :idea:
  2. CGN
    Likes: 9, Points: 18, Legacy Rep: 138
    CGN Senior Member
    Yes, raster to vector, taking dimensions form the blueprints, importing the actual picture of the blueprints and tracing on top of the image in autocad.
  3. Andrea Gail
    I tried to use the prints as templates and cut away parts from a block.
    But it didn“t wotk out very well :rolleyes:
  4. CGN
    CGN Senior Member
    Ok, involves lofting and fairing, the fact that you are tracing from the blueprints it won't warranty that the hull is fair itself, i should mentioned before, could be that the linea are not fair, or intended for construccion, or if you try to just trace in top of the blueprint in autocad and not fair again to check that everything matches it will be worng at the end for sure, is not going near to construccion.
    you must fair again after you traced the blueprint in autocad.
    There is other software like rhino that can do do that and check for fairness but you can do it in autocad, just go trough the lines and fair
