29' Catamaran Mold Laminate Thickness
Discussion in 'Fiberglass and Composite Boat Building' started by Paler, Apr 14, 2025.
  1. Paler
    Paler Junior Member
    Hi All,
    This 29' power cat has been in the works for a while now. I am building a plug to make a mold that would allow me to produce several units (estimated at 10-20 units before major retooling). The scantlings and layup schedule for the prototype hull have been estimated. However I am not sure on the mold's laminate thickness or materials.
    Does a 15mm mold laminate thickness with 1.5" sch 40 steel tubing bracing sound adequate? 15 mm would be equivalent to the keel region laminate thickness for this hull.
    The layup schedule in mind for the mold is like this:
    Tooling Gelcoat @ 25 mils
    .75 oz CSM
    1.5 oz CSM
    6 layers 1708
    6 layers 1808 (alternating with the 1808)
    Iso blend resin.
    I also have access to core mat, heavier matt, and woven roving.
  2. ondarvr
    Likes: 685, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    The 1708 will print through to the surface. You need more CSM or some sort of print blocking layer.
    Paler likes this.
  3. wet feet
    Likes: 610, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    I don't see any reason to use any glass other than basic CSM as it is easier to persuade to a hull shape and the loads on the tooling are pretty minimal,laminators walking around inside the hull or loads from the framing and wheels fed into the structure.I would estimate that a 4500gsm laminate would be more than sufficient with external foam stringers and plywood framing laminated to the external stringers.don't rush the bonding of the stringers to avoid local distortion.I do have a mild preference for a band of coremat beneath the stringers for this reason.
    Paler likes this.
  4. Paler
    Paler Junior Member
    Thank you, how much more CSM?
    Do you think I could do away with the double bias completely? Or maybe just on layer per every 5 oz CSM layer?
  5. Paler
    Paler Junior Member
    Thank you Wetfeet, it would make the layup easier. When you say foam stingers I envision like 10o x 100mm foam stringers both longitudinally and transversly, is this what you mean?
  6. wet feet
    Could be 100mm square,could be 60mm square,could be 100 X50.,depends on what you may have available.A couple of further points;plan for some pads to attach wheels to and don't forget to mark a waterline on the outside of the mould so that you can set it level.
  7. KD8NPB
    Likes: 40, Points: 28
    KD8NPB Senior Member
    Use square tube, not round tube. Round is too flexible.
    If you want to save cost, use plywood for supporting grid with a steel hoop to support.
    Typical laminate;
    Gel
    Skin , 0.75 to 1.5 oz
    Skin 2 , 1.5 to 3 oz
    Bulk , 3 to 6 oz
    CORE
    Bulk 2 , 3 to 6 oz
    Bulk 3 , 3 to 6 oz
    I would probably do something like this, with a morning and an afternoon lamination.
    Day 1;
    Gel
    0.75 oz skin 1
    Day 2;
    1.5oz skin 2
    3 oz bulk 1
    Day 3;
    1.5 oz bulk 2
    4mm coremat bulk 2
    3 oz bulk 3
    Day 4;
    3 oz bulk 4
    1708 bulk4
    1708 bulk4
    Use CHP/MEKP blend initiator to extend gel time and reduce exotherm, do not allow initiator percentage to fall below 1.25%
    We use Nouryon Trigonox 263.
  1. Naeem Nadaf
  2. Jaco
  3. Jolly Mon
  4. gaza
  5. BrissoDamo
  6. BlockHead
  7. Smj1
  8. useragentseven
  9. WerpKerp
  10. Racman
