23 foot sloop
Discussion in 'Boat Design' started by lincolnprh, Nov 4, 2012.
  1. lincolnprh
    lincolnprh New Member
  2. bpw
    Likes: 4, Points: 18, Legacy Rep: 34
    bpw Senior Member
    There should be a hull number somewhere on the transom, usually upper starboard side. The first few letters indicate the builder.
  3. lincolnprh
    no serial number, name plate anywhere
    thanks
  4. bpw
    bpw Senior Member
    Look harder, often are very difficult to see. They are stamped in and often get filled with grunge, paint etc. First places to check are upper corners of the transom, but not all builders where consistent.
    That boat looks new enough that it should have one, hull numbers have been mandatory for quite a long time now.
    http://www.boatsafe.com/nauticalknowhow/hin.htm
  5. PAR
    That boat's styling looks to be possably before mandatory HIN's in 1973. More pictures would be helpful with an upper starboard side of the transom shot in high resolution.
  6. WestVanHan
    Is this your boat or just a pic you found?
    Does it have a name on the back? I tried the side name-no luck.
  7. lincolnprh
    23 ft sloop
    thanks for the feedback, I'll get some more pics posted tomorrow
    pete
  8. philSweet
    Likes: 240, Points: 63, Legacy Rep: 1082
    philSweet Senior Member
    I think it's a Gary Mull design. See Ranger 23/26. Can't figure the rudder out though.
  9. PAR
    Yep, looks like the 23 and early versions of this boat wouldn't have a HIN on the transom. Good catch Phil . . .
  10. lincolnprh
    thank you
  11. sean9c
    Likes: 4, Points: 18, Legacy Rep: 35
    sean9c Senior Member
    Hull deck joint and rail detail don't look Ranger. I think it's a Newport 23, also designed by Mull. Built by the Newport that also did the C&C designed 27 and the Mull designed 30 and not a Venture built Newport 23.
  12. philSweet
  13. PAR
    It would be helpful to have basic dimensions on this boat.
  14. joz
    Likes: 0, Points: 16, Legacy Rep: 10
    joz Senior Member
    Ask and you shall recieve:p:D
    Lenght 23' 4"
    Beam 7' 11"
    Draft 3' 9"
    Bridge Clearance 31' 6"
    Headroom 4' 3"
    Power - Outboard 3 to 6 Hp
    Max Speed 6 Knots
    Fuel Tankage - Portable
    Water Tankage 12 Gallons
    Sail Area 264 Sqft
    Displacement 3,400 Lbs
    Approx Trailer Weight 5,000 Lbs
    Ballast 1,500 Lbs
    B/D ratio 44%
    SA/D 18.7
    D/L 190
    Motion Index 15.9
    Space Index 318
    Avg PHRF - 216
    Built Years from 1971 to 1979
    Designer: Gary Mull
    Builder: Ranger Yachts
    and Its not an IOR Boat she's a 99% cruising boat :D
  15. philSweet
    lincoln, are you still out there? The link to your boat is now broken. I still don't know what it is, but I just discovered a second one not half a mile from my house. It is also abandoned and looking for a good home. It has NC reg numbers so you could track it down that way and discover how the owner of this one registered it. Let me know if you want me to write down the reg numbers next time I go by. Talk about a weird coincidence.
  1. ExileMoon
  2. Turbopleb
  3. B Goodman
  4. Turbopleb
  5. Silvertooth
  6. Ned Lunav
  7. Keith777
  8. gofastguy
  9. DCockey
  10. robmcg25
