Note: This feature may not be available in some browsers.
I understood weight and strenght problems with my an exaggerated state of requirement.Each bridge section weighs 12,000 pounds.
Twin axles are more stable at high speeds. They help lower cg a bit, and make towing with a light tow vehicle a bit safer.
yeah 50mph on the highway . 1500km .Speed limits overall they are interesting, 40 ton truck speed limit is the same for hayabusa. Great, but it doesn't make sense to me.High speed? In Europe you are restricted in speed when towing, and rightly so.
How to connect 2 parts of the hull 3m stern + 4m bow?
It is possible to do this way but I would prefer to get continuity of the composite surface , connect the bottom and freeboards. Continuity for stretching forces not for hydro drag. In this case bulkheads will not be very necessary in the connection. Question is how to get it.End each hull section with a bulkhead, and use thru-bolts.
I read of course but I have an appetite for more hp outboards. Strongly strained and light structure.Take a look at "pistnbroke's" thread "Stacking boat in production"!
