waynemarlow
Senior Member
- Joined
- Nov 13, 2006
- Messages
- 435
- Reaction score
- 50
- Location
- UK
Dagger board strength
Dagger boards need to be thought through just a tad more than putting enough carbon in to not break. In fact you do need them to break if you hit an obstacle with them and that means sufficient strength in the case to hull areas just behind the bottom edge and the front edge at the top. Too much strength in the board will seriously compromise the hull and you are far better to break the board and sail on without, than punching a hole in the hull.
Also nothing is worse to repair than the case ( from experiance of breaking a board or two ) and around it as it inevitably means replacing the whole case ( surprising how a screwdriver in the appropriate place can delaminate the resin sufficient to get a whole case out without damaging the hull ) or cutting big holes in the boat to get to the case.
