21ft tunnel hull design questions.
Discussion in 'Boat Design' started by Mhall, Aug 26, 2013.
  1. TANSL
  2. Mhall
    Mhall Junior Member
    I have talked with Jim at Aeromarine Research a good bit about my plans and I agree, the software and analysis is a must for something of this nature. I almost said to myself it will be ok if I just build it and play with the weight and balance but, then I started thinking of how quick things happen at those speeds and weight and balance can not help when a hull has a major imbalance in the lift of the aerodynamics and the padded surfaces. Again, this design is heavily based on an existing well proven 100mph + boat but to be safe I want to do the analysis.
    I have never even considered building this boat without encapsulating all the wood in epoxy. I was even against the idea of using wood until i started seeing the quality high dollar boats being built using the simple cold molding of wood with epoxy.This boat will be totally encapsulated with epoxy resin for sure. I was mostly asking what the ideal layup scheduled would be as far as making the hull strong and durable. I am leaning towards going with thicker wood to gain more strength without adding more glass. The liberator 21 that I have had a good 1" of hull thickness at the transom on the padded surfaces so, I may want to mimic that and build up some thickness as well. I understand that the thicker the core material the more strength can be gained with the same layers of glass.
  3. michael pierzga
    michael pierzga Senior Member
    Plywood sheathed in Biax cloth makes a very good boat. 100 mph is the problem.
    Ypou should seek Pro advice.
