21' Sutphen questions
Discussion in 'Powerboats' started by teen, Feb 21, 2012.
  1. PAR
    Likes: 471, Points: 93, Legacy Rep: 3967
    The access door is likely to get at the sending unit and hoses. If you don't have a lot of experience with boats, then you should run in the opposite direction of this one.
  2. Mr Efficiency
    Likes: 273, Points: 83, Legacy Rep: 702
    Yes, a thirsty beast.
  3. IMP-ish
    Likes: 9, Points: 18, Legacy Rep: 150
    IMP-ish powerboater
    Other Q is how many hours on that 90's Evinrude?
    Bottom paint says maybe this sutphen has been used and in salt water more than trailer-kept boats.
  4. teen
    teen Junior Member
    if i was to buy this id want the tank fixed and it seems like a lot of work so im probably going to just pass on this one
  5. PAR
    Good idea to walk away. Most of the time a fuel leak also means fuel soaked foam, which isn't fun to remove.
  6. CatBuilder
    CatBuilder Previous Member
    Wow. It seems buying an entry level power boat is a much more difficult process than buying an entry level sailboat.
    Here's a picture of my first sailboat:
    About the only problem I had buying it was finding out that the mast would dishpan in the cabin roof (deck stepped) when it was properly tightened.
    No big deal... I just crammed a 2x4 in there for extra support. :)
    Sure, the pintles broke off and left me without steering once and the outboard almost never worked (staring a long history of that problem that continues to this day for me), but it was a reasonable boat for $2500 with trailer included.
    There just wasn't as much to look out for though: fuel tank issues, use of the boat in salt water, etc... etc... Much easier process.
