While running close to WOT, the RPM increased and shortly afterwards (20 seconds) it overheated. The motor was jacked and trimmed up a little higher than normal so thought that was the problem. Now it seems to maintain good water pressure & run normal temp at mid throttle but when close to WOT, at times we get the RPM increase again and then notice erratic water pressures (literally bouncing between 0 and 20psi) and overheating. Running in a tank, the water pressure at idle is good (2-5 psi) and the head temps are good (150F). Water pump, poppet and t-stats were replaced last year and we ran with no problems till now.
-My prop guy had to put some cup in the prop and advised it is pretty worn. Can a prop issue create a cavitation condition and cause the water pump to lose prime?
-What are the symptoms of poppet issues?
-Can poppet issues cause erratic water pressure?
