2 pot eurothane.
Discussion in 'All Things Boats & Boating' started by Frosty, Feb 1, 2009.
  1. Frosty
    Frosty Previous Member
    I have a gallon of 2 pot euorthane and have lost the hardener. I am told I can't buy some without a new gallon of paint,--its not cheap.
    I have tried epoxy hardener and some Jotun hardener without success,
    Its Joton Futura AS--white, Does any one know a way to get it to go off so as I can use it?
    I am just testing polyester resin hardener in the sun at the moment but not looking good.
    Im only painting the dinghy!!
    vinigar , bleach, hair shampoo, cellulose thinner,???????
  2. CDK
    CDK retired engineer
    The hardeners for polyurethane contain isocyanates, just like superglue.
    Loctite Hysol and Loctite 3183 are commercially available hardeners.
    You could try a few drops of superglue, but then you probably have to paint very fast!
  3. TeddyDiver
    TeddyDiver Gollywobbler
    :D :D :D
    Seems you need 50 helping hands..
  4. Frosty
    Hmmm interesting,---how fast will I have to paint?
    A few drops of super glue to how much paint?
  5. CDK
    Frosty, I have no idea. But when faced with your problem, I would do a small scale experiment. Using the paint without hardener leads nowhere: I did that once because the tin with the hardener got displaced and the paint tin carried texts in funny languages only, so I thought it was single component paint.
    Because it was still wet after a week I started searching and found the hardener. But spraying it over the paint didn't help anymore....
  6. Frosty
    I understand exactly what you are saying.
    Ive done that many times myself. Anyway I tried a single drop into a half a teaspoon bit of paint but after 5 hours its still soft.
    Hopefully in the morning its cured or ille try more super glue.
  7. robherc
    Likes: 5, Points: 0, Legacy Rep: 102
    robherc Designer/Hobbyist
    I just did a little research on Google. Wasn't able to find any listing of any specific chemical(s) that will cause it to harden. I DID, however, find information about using different "reducers" to alter the gel time, maybe you could use a slightly "faster" reducer & get a decent set w/o part 2?
