1995 Pursuit 2150 WA
Discussion in 'Fiberglass and Composite Boat Building' started by Bluewaterposer, Apr 15, 2026.
  1. Bluewaterposer
    Likes: 4, Points: 3
    Bluewaterposer Junior Member
    Hello, coming from BOB and well aware of Odarvr, in thr process of refurbishing the pursuit above.
    It's a father son project, we have the back deck removed and will be replacing stringers and have transom almost ready to rebuild with Coosa 26 BW and 1708 and csm for first layer prior to 1708.
    Our schedule, csm, 1708, 1708, 1708, csm Coosa. Then 3 more 1708 to tie in to hillsides and gunnels.
    Much tabbing as well.
    Thanks in advance!
    BWP
  2. Bluewaterposer
    Likes: 4, Points: 3
    Ooops! Vinylester and 1708 from Fiberglass Florida, they are local to me in Stuart, FL.
    Next question, I want to post pics.
    Thanks,
    BWP
  3. bajansailor
    Likes: 1,869, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome to the Forum BWP.
    Yes please re posting some photos of your project - although I think there might be a requirement that you have to make a few (perhaps 5?) posts first before you can post photos?
    You can add photos by clicking on the 'upload a file' in the box at the bottom right.
  4. fallguy
    Likes: 2,039, Points: 123, Legacy Rep: 10
    Not really much need for csm at the coosa if you are laying on csm backed 1708. It offers little strength for the weight.
  5. Bluewaterposer
    Likes: 4, Points: 3
    Thanks, the only reason for so doing csm is it will be a tight layer before the stitched csm of the 1708 is laminated.
    More grinding, pictures soon.
    BWP
  6. Bluewaterposer
    Likes: 4, Points: 3
    Almost, after picture.
    BWP
  7. Bluewaterposer
    Likes: 4, Points: 3
    20260401_184226.jpg earlier
    BWP
  8. Bluewaterposer
    Likes: 4, Points: 3
    Way before. Have been watching Fishbump YT and like his application.
    BWP
  9. Bluewaterposer
    Likes: 4, Points: 3
  10. bajansailor
    Gosh, that is a massive re-fit project you have there!
    Yet at first sight (of the photos) the 'before' photos do not show anything amiss, never mind that plywood is quietly rotting away behind that nice gelcoat.
    Did you use that impressive gantry to lift the deck and cabin moulding completely off the hull?
    If so, do you also have some photos of the hull interior before you started to cut out the stringers that you are replacing?
  11. Bluewaterposer
    Likes: 4, Points: 3
    Transom first, then stringers 2 at a time to maintain hull integrity.
    Cabin still attached, for now.
    Short story, prior owner absolutely loved this hull, started smelling fuel really bad, decided to replace the tank, when tank pulled, port stringer came with it.
    He abandoned project and my son got it for price of trailer.
    BWP
    ondarvr and bajansailor like this.
  12. fallguy
    Be careful with hull deformation if the stringer pulled out.
    Best to support the hull flat and then repair one stringer at a time.
    If you leave the boat on the trailer with the stringers out; good chance you’ll hook the hull and that is very bad for performance.
    Also, verify no balsa core in hull exists or if it does; is rotten.
  13. Bluewaterposer
    Likes: 4, Points: 3
    Cabin still attached, trying to strengthen under the cabin without full removal.
    Ouch!
    BWP
    bajansailor likes this.
  14. fallguy
    What is keeping the hull from deforming where the stringers were?
  15. Bluewaterposer
    Likes: 4, Points: 3
    Besides the bunks bracing under the keel sides.
    I'm the free labor for my son, his idea, he is the boss.
    Thanks.
    BWP
