1992 / 1993 Seaswirl 195 SWL purchase
Check out the kill switch wiring to make sure it isn't a broken wire.
So major rebuilding done, stripped all rotted wood, removed old paint and painted everything again.
I am currently reviewing prop as I have 13x19 on johnson 140 HP which struggles to plan.
I was thinking I need to change prop pitch to one of the follwoing:
1. Aluminum 4-Blade - 13.75 x 15 RH (13 Spline)
2. Aluminum 4-Blade - 13 x 15 RH (13 Spline)
3. Aluminum 3-Blade - 13.5 x 15 RH (13 Spline)
4. Aluminum 4-Blade - 13.25 x 17 RH (13 Spline)
Any recommendations suggestions? Boat loaded is around 3000 to 3500 lbs.
