seasquirt
Senior Member
- Joined
- Dec 29, 2015
- Messages
- 384
- Reaction score
- 199
- Location
- South Australia
Most carbs have the float level needle and seat we all know, and also the long main jet needle attached to the slide or diaphragm, which opens closes many small holes in the sides of the brass tube; and then also the bleed needle adjustment at the side for either fuel or air depending on where it is - cylinder side or atmosphere side, as I mentioned above - which can be bottomed out. Also the low speed jet which has no needle but can get blocked anyway. Clean them all.
If all the bleed needles were closed off then someone had set them up wrong most likely. Often they are very pointy brass, with a tiny O ring near the point, then a tiny metal washer, then a tiny spring butting to the thread, and another small O ring closer to the outside near the adjusting slot, to stop fuel leaking out. If the O rings were damaged / missing and leaking fuel someone may have closed them off. Find an exploded view diagram, and maybe 3 carby kits containing all new brass and O rings and washers and seals. Keep the old bits as backups. You'll be an expert soon.
