1989 4.3L - upgrade to 5.7 or newer 4.3L questions
Discussion in 'Gas Engines' started by pfouts, Dec 1, 2010.
  1. pfouts
    pfouts New Member
    I have a 1989 Ebbtide Rivera with a 4.3L engine with a cracked block . I would prefer to upgrade to a 5.7L and if that is not possible, to upgrade to a newer 4.3L Vortec long block.
    I believe I have enough room for the 5.7L - however anyone know the difference in length of the block?
    Since the boat has fixed motor mounts, does the 5.7L block have mount locations anywhere near the 4.3L ?
    And if the 5.7L is not possible, anyone know of issues replacing a 89 4.3L with a newer vortec - that way I can have a smoother engine and there seem to be some upgrade options with 4bbl manifolds available for the vortec engines.
    Thanks for any suggestions,
    Pat
  2. rasorinc
    rasorinc Senior Member
  3. gonzo
    Likes: 1,718, Points: 123, Legacy Rep: 2031
    If you change the engine to a 5.7, you will have to re-gear the transmission too.
