1976 Ford 302 Engine oil?
Discussion in 'Gas Engines' started by babs240sx, Jul 4, 2010.
  1. babs240sx
    babs240sx Junior Member
    I just bought and am fixing up a 1976 hawaiian, Im new to the ford 302 engine it has in it and wondering what weight and brand oil you guys recommend. Also how many quarts I need to put in it?
    Likes: 1,718, Points: 123, Legacy Rep: 2031
    There were originally used with 30W but you can run them with 10W40 which is more efficient. It should take 5 to 6 quarts depending on the oil pan model.
  3. FAST FRED
    FAST FRED Senior Member
    It may be more fuel efficient but the straight 30 will give the engine a longer life , as long as it is not so cold (below freezing starts ) where the water thin oil is needed.
    FF
  4. babs240sx
    Ok should I be using synthetic
  5. gonzo
    Synthetic is better.
