By the way, how does one work from the inside on this boat with the bow tube? Is it possible to get under the tube?
I think you're lucky and hopefully you won't have to.
I'm still saying this may be too challenging but the inner surface is in nice enough order that you may be able to if you get a more experienced friend to assist with the glassing.
Me, I'd do it as follows - though there are many other possible routes.
Flip the boat over and put on stands - low enough that you can reach all of the damaged area easily but high enough you arent bending too much.
you may well be removing at least 4 sq feet based on those pics but only the outer laminate and any damaged core - do it a bit at a time and stop when the core seems solid and dry.
use a grinder VERY CAREFULLY to remove the outer and the sandwich (BREATHING PROTECTION and a disposable coverall and spray sock hood - duct taped to the gloves and you'll still itch for about 3 days).
feather the edges of the old glass
you don't want to pry /lever the old core as you risk damaging the inner which you absolutely have to save!
repair the inner where it is holed - sukisolo's trick with the tupperware might help - ive sometimes glassed onto a sheet of thin plastic let set and then peeled of the plastic to give a solid repair panel which can be glassed on. When hard cover the whole area with a layer of Bi-axial or CSM properly wetted and worked in with lots of resin.
Dont know how thick the sandwich is so either several layers of matting if very thin, micro balloons if thicker or foam/wood strips if thick.
Hull should be close to original thickness now - so another layer of Biaxial or two and you want to overlap the feathered original edges, finish with a layer of tissue and a flowcoat of wax added gelcoat.
If I made that sound simple - it isnt - its simplified!
excuse the sketch but it might help
