Figure I post so people that know more than me can tell me what I did wrong for next time. This time well its too late. I got some helpful information last year when I removed my I/O and went outboard. (Should of done the tank then)
19.5 Glasply
Belly fuel tank started leaking last week in July. Cut the floor on July 28th with hopes of being back on the water this past Labor Day weekend but I feel behind a little.
Tank was 28 years old and I'm surprised it lasted this long. I always said when the tanks leaks I'll put my fish box in the floor so I went for it.
Crappy before pic. Fish box on deck and was always a PITA to get over it to the helm.
Cutting the floor. Fuel tanks was foamed making it a ***** to remove. Stringers are dirty as hell but in good condition. No wood there also so saved me time by not needing to replace.
I would of loved custom tanks but due to my tight (self inflicted) dead line I got lucky and my local West Marine had (2) 35 gallons tanks in stock. Old tank said it was (76) but calculating volume after I pulled it was more like (60).
Test fit the tanks and starting to foam in the fish box.
Back half of the deck
Test fit battery box and little extension I added to hide the PVC coming from under floor.
Wiring mess under the dash now.
And as of Tuesday afternoon.
https://www.youtube.com/shorts/ZO1pqsKVdbY
I used poly resin for almost everything except the first layer in the fish box. I used epoxy and 1708 for the first layer. Then switched to one more layer of poly & 1708 then gelcoat.
Only have chairs to install, bleed the steering and hit the water.
If I had a choice to do it again I would just replace the tank and I would of been back on the water already. Not to mention all the damn hours living in the boat.
19.5 Glasply
