16 Degree Deadrise
Discussion in 'Boat Design' started by mikey483, Feb 24, 2007.
  1. tri - star
    Likes: 1, Points: 0, Legacy Rep: 3
    tri - star Junior Member
    Yes RANCHI OTTO:
    I have been busy.....
    Will be sending you a private message.
    Cheers.
  2. Kobus Potgieter
    Likes: 1, Points: 0, Legacy Rep: 10
    Kobus Potgieter Naval Architect
    Hi
    I have been involved with rib designs since 1984. I dont know the seastate which are mentioned in that area but the best combination for the size boat (8 - 8.5m) going offshore is a 20 - 22 deadrise. Ging up to 23 is acceptable but all depends on the hull design. If the chine beam is designed in such a manner to assist the boat with early planing, its great. A 16 deg deadrise on the boat mentioned - wear a kidney belt or fit the boat with suspension seat.
  3. RANCHI OTTO
    Likes: 37, Points: 0, Legacy Rep: 535
    RANCHI OTTO Naval Architect
    This is the cross sections of the REFOLO ASD (Arrow System Design)
    length = 6.2 m
    breadth at transom = 2.4 m
    power = 1x205 hp
    speed = 45 knots
    deadrise = 22 deg.
  4. Guillermo
    Likes: 188, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Nice hull, Ranchi. A frind of mine (unluckily dead in a terrible accident) used that kind of hull forms more than 15 years ago, here in Vigo. He produced several patrol boats for the Customs, around 12-14 m long (if my memory doesn't fail me) which performed pretty well. I think there are still some of them around.
    Cheers.
    P.S. Is your site http://www.ranchidesign.com/ with problems? I cannot reach it.
  5. Guillermo
    Kobus,
    What would you say it would be a nice chine beam for a typical 7.5 m rib, for it to go easily in the planning? I have experienced problems with one having 18,5º deadrise and 1,94 m chine beam at the stern. Not easy to be brought into plane with an estimated 70 HP/Ton (jet) :confused:
  6. RANCHI OTTO
    To Guillermo..
    The boat was the OCEANO ASD 9 (see my gallery) built by my ex-friend J.Barreras Larramendi in Vigo.
    The steel boat reached the speed of 60 knots...
    After the first boat, J.B.B. copied my ASD with poor success....(friends!!)
    I have spent long time in Vigo and Galicia with my friends Adrio (father and son) screw manufacturers.
    Galicia is fantastic......only beautiful souvenirs! (people, food, nature etc.)
    I have visited more than 50 countries but Spain and Galicia......:p
    My new web is under construction. For my designs see my gallery and for ASD tech. specification the web www.adragnayachtdesign.com
    Juan is dead? we are speaking of the same person?
  7. RANCHI OTTO
    This is the OCEANO ASD 9 with me and my ex-friend J.L.L.B. on board during sea trials in the Vigo bay....
  8. Guillermo
    Yes, José Juan Barreras Larramendi had a terrible car accident more than 10 years ago and died instantaneously. His son José kept on with the Oceano boatyard, but finally desisted. I see him here and there from time to time.
    I didn't know the Oceano boat design was yours.
    Whenever you come to Galicia, you know where I am. I'll be delighted to meet you. We'll enjoy some 'marisco' poured with 'albariño' wine....:)
    All the best.
  9. RANCHI OTTO
    Thanks Guillermo,
    I'm sorry for the dead of Juan. Copy patented hull shape is nothing if compared with the tragedy for the family...
    ciao Otto
  10. Willallison
    Willallison Senior Member
    Holy crap Ranchi ! Do I count 6 V8 Evinrudes on the back of that thing !?!?!
    Absolutely fabulous - bugger the fuel consumption... all boats should suck it like there's no tomorrow!:D
  11. RANCHI OTTO
    Yes....6 outboard engines x 275hp.
    To reach the speed of 60 knots in Ocean with a STEEL boat...no other possibility!
    Consumption during sea trials....500 lt/h gasoline abt....!:p
    With the ASD (Arrow System Design) hull no problem to install them.
      File size:
      112.3 KB
      File size:
      131.1 KB
  12. ALowell
    ALowell Junior Member
    Otto:
    What is the purpose of the bulges toward the aft of these boats? Do they offer static stability, or is there more to them?
    ~ ALowell
  13. RANCHI OTTO
    PROBLEMS OF TRADITIONAL HIGH SPEED HULLS
    The evolution of engines and propulsion systems has not been accompanied by innovative hull designs giving support to the concentration of weight in the aft part of the high speed hulls.
    The main problems of classical high speed boat are as follows:
    Porpoising phenomenon at all speeds due to difference between the longitudinal center of gravity and the longitudinal center of buoyancy. The distance between these two centers it too large in the traditional "deep vee" hulls because this hull shape is not suitable for the modern systems of propulsion.
    Longitudinal trim angle at running condition. The difference of the two longitudinal centers, as described above, generates a boat running with an important trim angle. This is a handicap because the propulsion is working an inclined flow with loss of efficiency. Visibility and bow acceleration in waves are other negative points.
    Large heeling angle by steering leading to loss of stability. This phenomenon is well know and is due to the important deadrise angle of the bottom. The lack of volume in this area forces the boat to extreme heeling angles with dangerous decrease in stability. If these problems are at an acceptable level for sport boat drivers, they represent an open problem for military boats.
    Concerning military craft, "deep vee" hulls are not able to withstand overloading in weight (ammunition, troops. fuel oil, etc.) due to lack of immersed volume of the hull.
    ASD (Arrow System Design) is a hull shape invented for the modern propulsion systems and is able to avoid problems deriving from high speed.
    The ASD (Arrow System Design) hull consists of a central deep vee hull having two special shaped annexes in the aft.
    ADVANTAGES OF THE ASD HULL
    The longitudinal center of buoyancy is closed to the longitudinal center of gravity well aft, allowing the boat to run parallel to water at high speed. The propulsion system works at optimum efficiency and in favorable conditions.
    The heeling angle of the boat is not in excess of 5°, thus allowing very secure and stable maneuvering. The two lateral annexes with their optimal shape, reduce drastically the heeling angle at fast turning. I've tested the VILLE DE CAVALAIRE ASD at 100 m.p.h. without touch the throttles by full steering..... (picture of the boat is in my gallery)
    The fore part of the boat is relatively thin with a high-placed chine. In this way the boat has an optimal response in rough sea contitions.
    High stability in all sailing conditions due to the two annexes that give very high values of GM.
    The ASD hull is very receptive to an overload in payload with no substantial decrease in performance due to the high value of waterline surface.
  14. RANCHI OTTO
    In my Forum gallery you will find the video of the NAJA ASD during steering trials at 50 knots.
    The boat has the following main dimensions:
    Material > aluminum
    Length o.a. > 12.0 m
    Power > 4 x 300 hp
    Speed > 52 knots in tropical conditions
    sold 40 units to Gulf area country)
  15. RANCHI OTTO
    This is the boat:
