12v/24v
Discussion in 'All Things Boats & Boating' started by russglass, Jan 9, 2009.
  1. russglass
    russglass New Member
    hi guys what r the pro and cons between a 12v system and 24v system for a 31ft sailing cat
  2. Guest62110524
    Guest62110524 Previous Member
    mainly your 31 cat, will have iddy biddy engines, where 24volt crank /charge is not offered
    BUT 24 volt beats 12 hands down, except there are no 24 vdc electronics , eg radio, pilot, you name it so you have then to have to settle for transformers,blocking diodes, tapped batt banks etc,
    so nope , short answer, stay with 12 vdc
  3. russglass
    12/24v
    thanks whoosh i am using 50hp 4 stroke o/b's
