12 seater and 25 seater boat
Discussion in 'Boat Design' started by prathab, Jun 8, 2016.
  1. prathab
    prathab Junior Member
    hi ,
    i am looking to build 12 seater and 25 seater ocean going passenger boat to charter...
    where do i get proper design stock plans ? at least to get proper hull design & i can modify the seating arrangements ,,,
  2. TANSL
    Likes: 414, Points: 93, Legacy Rep: 300
  3. prathab
    want to build two boat one is 12 seater outboard engine boat made out of fiber glass contruction,,, to be used for charter on sea water... length will be around 7 to 8 meter , beam 2.3 meter or less , draft as standard ,,,
    second is 25 seater same purpose as mentioned for 12 seater , length will be around 10 meter ,
    can any one help me to find a right design plan to build ,,,
  4. TANSL
    The possibilities are endless. Try better define your preferences.
  5. prathab
    thanks tansl ,
    where do i get the design plans? i hve been surfing in web couldnt find plans like this
  6. TANSL
    First you must clarify the type of boat you want. Without this, it is not worth to continue talking.
    In any case, my advice is to not keep looking on the net because you will not find the design drawings and, even less, the construction plans.
    You better look for a good professional, close to your surroundings, and begin to walk guided by him.
  7. Rurudyne
    Rurudyne Senior Member
    Refugee boat? :p
  1. marthandan
  2. 87jct90
