12- 13 ft Catamaran RIB w/hydrofoil
Discussion in 'Multihulls' started by sail4evr, Mar 8, 2008.
  1. sail4evr
    sail4evr Junior Member
    Does anybody know of any current/active builders of this type? This is a powered dingy/tender Not a sailboat
  2. Nojjan
    Likes: 4, Points: 18, Legacy Rep: 30
    Nojjan All thumbs...
    I am sure you have seen the Professor KG Hoppe's HYSUCAT concept, smallest built is around 20ft or so but as small as 12-13 ft sound like taking it too far down in size. It will of course work to some extent but I wonder for what load?
  3. sail4evr
    I don't really understand your response. I have seen hydrofoils under a chair being towed by a water ski boat. I've seen 10 ft moths, a sailboat on hydrofoils, what is different about a 13 ft boat with hydrofoils? Load should be around 900 kilos.
  4. Meanz Beanz
    Likes: 33, Points: 0, Legacy Rep: 585
    Meanz Beanz Boom Doom Gloom Boom
    That sounds heavy ! My 24' cat is 900kg and I wouldn't like your chances of getting it up on foils. Moths are as light as a feather and sailed by scrawny fit young lads, not a craft for everyone. I think all that Nojjan is saying is its probably easier to get the numbers to work with a little more size to offset the crew load. The smaller you go the tricker that gets.
  5. Nojjan
    Thanks MB, that is somewhat clearer than my reply I guess. Yes, a 900kg square block of concrete can be made to run on hydrofoils, but under what conditions ;-), I'm sure that chair was nice and dry when they decided to stop.
    Any-who, if it is intended to be practical (maybe not in the scoope here) I would aim at a larger size. Note some of the findings from Hoppe, smaller HYSUCAT's are much harder to balance (LCG sensitive).
    But I don't want to dampen your spirit, please continue with your project.
  6. sail4evr
    So I gather that hydrofoils are not competitive in weight carrying capabilities with a traditional RIB inflatable of 13 ft (3.8m)? Many of which exist in the combined weight plus load of 900 kg. Is that right?
  7. Meanz Beanz
    I'm talking about sailing boats, if its a power boat and you chuck enough horsepower at it and yeah I am sure its possible. Still sounds like alot of weight in a 13' craft to me, but if you say so... beyond my experience. I could not say much more than that :D
  8. sail4evr
    Sorry for the confuision. I'm looking for a 12.5-13 ft dingy/tender hydrofoil for my 44ft sailing catamaran
    There are lots of rigid bottom dingys out there with a combined weight plus payload around 900 kilos.
  9. Steve Martin
    Steve Martin New Member
    Not a CAT and not with a hydrofoil, but you may like it. Have a look at http://www.africancats.com/boten_inf.asp?boot=48 and then click on "CATALITE RIB Specs" under Specifications. Built by a sailboat maker.
    Have a look at http://www.duxboats.com/dux_inflatable_boats.html
    The dinghy http://www.duxboats.com/d300specs.html doesn't meet your payload requirements but http://www.duxboats.com/pd400specs.html has a payload of 825 kg (1820 lbs). If you're on the west coast, use http://www.duxinflatableboatsofcalifornia.com/ instead
  10. sail4evr
  11. royalray
    royalray Junior Member
    hysucat 5 mtr
    Hi
    Try Watermarque Marine Ltd on www.worldwatertaxis.com thye have teamed up with Malan Conradie and Globally market the Hysucat range now they do have a small Cat foil tender or try www.hysucatstore.com
  12. Doug Lord
    Doug Lord Guest
    Here is a picture taken of a picture in the latest Seahorse magazine. It is a 49er sailboat hull converted to an outboard hydrofoil by one of the employees at Bethwaite Design in Sydney:
      File size:
      197.7 KB
