rangebowdrie
Senior Member
- Joined
- Nov 28, 2009
- Messages
- 342
- Reaction score
- 148
- Location
- Oregon
Particularly in sailboats with keel stepped masts, a bulkhead is placed close to the mast to take compression loads on the hull. The shrouds try to squeeze the hull sides together.
Without that bulkhead, (or if it's severely cut away,) builders frequently install a tension rod to prevent the hull squeeze from lifting the deck, transferring an athwartships compression load into a vertical tension load, but this entails a "beefed-up" side deck/cabin side/coach-roof structure as the side decks and coach-roof are not in the same plane.
