ram68ocean
Junior Member
- Joined
- Mar 13, 2013
- Messages
- 50
- Reaction score
- Location
- Europe
Could you think of any negative points or cons of placing a 100ekW main generator set placed transversely instead of longitudinally?
Note: This feature may not be available in some browsers.
It would be for a 15m workboat with electric twin thrusters (no propeller shaft arrangement).
Hi. The maximum rated power output of this generator set is 99ekW (but the question is generic to any size)What will be the power output of this generator?
...In my country, at least for fishing boats up to 24 m in length, the Administration finds it difficult to accept the transverse arrangement.
Yes, there are some potential downsides to installing a 100 kW generator set transversely instead of longitudinally. A transverse layout can reduce maintenance access to key components like filters, the alternator end, and belts. It may also complicate cooling airflow, increasing the risk of recirculation or hot spots that could lead to derating. Exhaust routing can become longer or tighter, adding backpressure. Vibration loads and mounting requirements may change, requiring extra structural consideration. Plumbing for fuel and oil drains can be less straightforward, and noise control may be more difficult if loud components end up closer to occupied areas. Finally, some manufacturers specify orientation limits, so warranty approval should be checked before installing.It would be for a 15m workboat with electric twin thrusters (no propeller shaft arrangement).
To me placing the generator transversely sounds counter-intuitive, non-standard, out of place somehow, but I would like to know why.
I thought about the effect of angular momentum on the wrong direction of the engine moving parts having an effect on vessel motions, checked a home generator calculator to estimate loads and placement, and issues with the structure. Will ask Genset supplier.
... there are some potential downsides to installing a 100 kW generator set transversely instead of longitudinally. ....
No.Could you think of any negative points or cons of placing a 100ekW main generator set placed transversely instead of longitudinally?
