10 oz. Uni with 2.5 oz. 4 harness satin weave
Discussion in 'Materials' started by Scuff, Oct 12, 2022.
  1. Scuff
    Likes: 44, Points: 28, Legacy Rep: 10
    Scuff Senior Member
    I bought this material along with some 17oz biax from a surplus supplier. I was thinking of using it for stringers to reduce unsupported panel widths. Does anyone have experience with this type of cloth? It's very supple. I believe it's manufactured by hexcel. I attached a picture of the cloth and tag. A web search turned up nothing. Any thoughts on suitability for longitudinal stringers? I'm going to contact hexcel today and see if they have any information. Thanks.
  2. ondarvr
    Likes: 699, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    What type of construction will you be covering? Is this a wood boat and you're encapsulating the wooden stringer using epoxy, or are you rebuilding a stringer in a fiberglass boat with polyester resin.
  3. Scuff
    Scuff Senior Member
    It's pvc cored construction. New build. The stringers are called for anywhere the unsupported panel width is over 20". I attached the info provided by Ed. Thanks. PXL_20221008_153719006.jpg
  4. Scuff
    Scuff Senior Member
    Called Hexcel and they confirmed it is 10oz uni with 2.5 oz in a harness weave. They don't have a data sheet for it. It's also pretty old. They have a pretty good fabrics handbook but the guide doesn't list a shelf life but does mention it. It was properly stored in a warehouse and isn't stiff or discolored. Is there a way to field test it to be sure it's useable?
  5. rxcomposite
    Likes: 636, Points: 113, Legacy Rep: 1110
    rxcomposite Senior Member
    The Style 525 isn't in my old database. How is the Uni connected to the harness satin weave? Is it woven into the satin weave? Stitched?
    We can find the corresponding directional strength. Maybe.
  6. Scuff
    Scuff Senior Member
    Thanks it's woven not stitched.
  7. Scuff
    Scuff Senior Member
  8. rxcomposite
    That means it is a uni woven with transversal fabric in harness weave. Basically a WR but with enhanced properties in the Uni or 0 direction. An unbalanced WR.
    No, you cannot use it in stringers. You need biax for the stringers as the web of the stringers are in shear and biax is very good in shear. Something in the order of 1.8 to 2.5 times the strength in the longitudinal direction.
    Webs are like the diagonals in a bridge structure.
  9. Scuff
    Scuff Senior Member
    Thanks so much. I've got plenty of biax.
  10. Tops
    Likes: 130, Points: 43
    Tops Senior Member
    Looks like there is an answer to Scuff's question but I am hoping to understand the weave.
    -Is it something like this, with the horizontal/gray being 10oz and the vertical/white being 2.5 oz?
    -For the sake of figuring, perhaps with Vectorlam, could it be looked at as 1 layer 10oz uni 0 degrees and 1 layer 2.5oz uni 90 degrees?
  11. Scuff
    Scuff Senior Member
    Tops likes this.
