10 HP Four-Stroke Fuel Consumption
Discussion in 'Outboards' started by Doug Lord, May 28, 2011.
  1. Turnpoint
    Likes: 1, Points: 0, Legacy Rep: 10
    Turnpoint Junior Member
    20hp Yamaha 4stroke
    Don't think you want a high thrust at those speeds.
    Have you thought about a 20hp Yamaha 4 stroke... It does not weigh much more than the 10hp.
    We put one on a 24 foot powertri we designed and built... Boat does 23 knots wot. I really love that little motor. One thing to note is that at wot it is burning 2.5 to 2.8 gph which is above what the manufacture states...but burns .1 gph per hp at 1/2 to 3/4 throttle.
    I wish they made outboards in this size with electronic fuel injection.
  2. nukisen
    Likes: 8, Points: 0, Legacy Rep: 124
    nukisen Senior Member
    Hi Lord!
    I have a 6.5hp engine the spec tells me that it will consume 396gram of petrol/hour/Kw this tells me i will consume about 1.5 litres at full throttle. though not an marine engine but I will use this anyway.
  3. nukisen
    Picture!
    A picture regarding the engine spec.
  4. keysdisease
    Likes: 43, Points: 28, Legacy Rep: 324
    keysdisease Senior Member
    Turn Point may have a point re 15knts vs hi thrust outboard. I think the hi thrust will get you to 15 knts but you may find yourself at WOT.
    I have used small outboards on many many sailboats, and there is a Major difference betweeen a "regular" OB and a Hi Thrust. This difference is most apparant when going into gear from a standstill. With the regular OB you put the critter in gear, give it gas, go to the cooler and get a drink, look around to see the way is clear, and about then you notice the boat is beginning to move. With the Hi Thrust motors it is advised you be holding on to something when you put it in gear as you will start moving immediately.
    This is of course a bit exagerated, but not by much.
    And a last comment about the Yamaha 9.9 hi thrust 4 cycles. I used to grind the heck out of the starter gears until I finally learned to check the pee holes before turning the key. At idle from 10ft? away I usually couldn't tell if they were running by listening for them.
    Steve
  5. Doug Lord
    Doug Lord Flight Ready
    Thanks, you're sure right about the weight:
    9.9 high thrust http://www.boats.net/outboard_motor/Yamaha/9.9HP/parts.html
    20hp http://www.boats.net/outboard_motor/Yamaha/20HP/parts.html
    And the cost isn't too much different....
