“Calculate the wind load in the direction of the incoming wind from 0° to 180° with an angle of 30°
Discussion in 'Hydrodynamics and Aerodynamics' started by sun, Nov 3, 2021.
  1. sun
    Likes: 12, Points: 18
    sun Senior Member
    When calculating the action of wind or waves in different directions on offshore structures, why only calculate the "0°~180° load in the direction of the incoming wind or waves"? Why are all "30° angles as an interval"?
    Likes: 2,123, Points: 123, Legacy Rep: 2031
    The maximum force is the only value of interest. That is what the design loads are.
  3. sun
    sun Senior Member
    I want to calculate the force on a structure. How to choose wind direction or wave direction? (10°、20°、30°......360°)?
  4. CT 249
    Likes: 82, Points: 48, Legacy Rep: 467
    CT 249 Senior Member
    What force and why?
    As Gonzo implies, this is not a simple question.
  5. sun
    sun Senior Member
    A new marine structure.
  6. gonzo
    Unless you are one of the sea gods, you don't get to choose the direction/force of the wind and waves. You need to use observed values for your location.
  7. TANSL
    Likes: 884, Points: 123, Legacy Rep: 300
    As in many other calculations, it is difficult to know a priori which is the worst circumstance. One must calculate several options to know which is the worst condition among the several possible ones.
  8. wet feet
    Likes: 594, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    Surely you ought to calculate the loads that may be imposed from any direction.Failing to include all scenarios would be negligent.
    TANSL likes this.
  9. sun
    sun Senior Member
    Thank you everyone for your valuable feedback.
  10. powerabout
    powerabout Senior Member
    yes all the forces can be calculated, the offshore industry does it all the time.
    Sometimes from wind tunnel data if availible
    The Dynamic Positioning industry is required to do this on Dp vessels.
    You get printed tables from the DP supplier and the data is used in the DP software.
    You do front area and then beam area, wind calc at 10metre level std air density and then there are formulas to do the other angles.
  11. powerabout
    is common practice offshore and lots of companies do it
