PAMA: "TRITONE 80"
TRITONE 80
Space flexibility and dynamic efficiency
An 80 ft motor yacht in fibreglass with 7 kw photovoltaic systems
The central idea of the whole work has been based on the desire to produce an aestheticallly competitive form, with the other boats of the same segment on the market,using photovoltaic modules and wind blades.
A boat that can be transformed thus making it possible to live at sea comfortably while respecting the environment.A hybrid concept,a connecting point between the sea and the sky.This project is almost a floating architectural structure,a living space that puts two fluids together.But the wings in this project are not needed for flying,but for increasing the photovoltaic module surface.The wind blade system,in carbon,is connected to the aerial shaft.When the boat is moored ,the fore wings can be raised so as to have two comfortable,reserved areas,sheltered from the sun and fitted out with tables and sofas.Another transformation can be obtained by removing the side),raising the sun-shades and sliding back the main deck windows:by moving the backs of the sofas a side cockpit can be obtained.
