Tanton: Red Line 35. Cat-Sloop
Interior.
The interior shown is one of many available and was designed for two people living aboard. Four sea berths are also provided. The aft cabin on the port side has a 54' wide berth and uses the chart table seat as a place to seat down. The chart table utilizes a 24' x 36" work surface with room to install navigation instruments. The port settee can be used as a sea berth and for dining seating with a flip up table section. Forward of the head is a separate sit down shower area that does double duty as a walk through to the forepeak which can be used for storage and a work bench. The L-shaped settee is surrounded by cabinets, lockers and book storage. The functional Galley has plenty of counterspace, two large sinks, propane stove and oven, fresh and salt water provisions and a well insulated ice-box. The foul weather gear locker separates the galley and the starboard quarter berth which is another good sea berth. A grate located at the bottom of the companionway provides drainage for wet gear. Other items of note are the 6'-3" headroom, 2-3" of foam insulation throughout and 80 gallon water capacity. the wood work is high grade birch with mahogany trim. Three opening hatches and 2 dorades provide both light and ventilation. Many of the interior items can be revised to reflect the individual preferences and use of the boat.
Above text from the brochure.
- Category:
- Tanton
- Sep 8, 2009
