Disposition of Motors on 8' Catamaran Quadcopter
colinhilton
colinhilton: Disposition of Motors on 8' Catamaran Quadcopter
A mock-up of the layout for flight-testing in hover and ground-effect transition to water. The initial format would be likely to feature fixed lift-motors forward and vectoring rearward, as the latter apply a slight nose-down pitch in the cruising condition that could be compensated for by running the former. Nonetheless a priority for testing is to fit only the rear motors in the perpendicular in order to evaluate performance as a pure hydroplane. Motor mounts seen here are fixed, but could be replaced by axles in the event that power-units require vectoring. Note that additional pusher-units could be applied at the stern in this layout, tho' rear lift motors and propellers would need to be stowed prior.
Posted by: colinhilton - website: https://www.teledrone.com
colinhilton, Jul 25, 2024
  • Category:
    Projects in Progress
    colinhilton
    EXIF Data
    File Size:
    1.5 MB
    Mime Type:
    image/jpeg
    Width:
    3837px
    Height:
    2878px
    Focal Length:
    3.99 mm
