Nohona Mau: Assemble BMS Control board
Battery Management System CPU required for any Li battery installation to monitor and control Low Voltage and High Voltage (overcharge) conditions. Also BMS ties to the Smart Charger assocaited with this battery bank via a data CAM bus connections. Contactor Relays are rated fro 250Amps or higher. BMS CPU programmed to LV disconnect after 80% of bank's capacity is depleted. Over-Ride (manual) controls allow for activation of LV or HV relays under emergency operation so battery bank can be fully depleted if necessary, or disconnected from the Charging Bus is it needs to be isolated.
- Album:
- Lithium Ion Battery Upgrades
- Nohona Mau
- Feb 16, 2017
