8.2m powerboat
Alik
Alik: 8.2m powerboat
8.2 m powerboat
Posted by: Alik - website: http://www.amdesign.co.th
Alik, Dec 15, 2007
    • Rating:
      5/5,
      Sean Herron
      Hello...
      So what is your trick for doing those 'X-ray' shots - will you divulge your method...
      I could see taking two shots from a render - one with the deck layer off - one with it on - and then composite in Photoshop and play with the transparency of the shot with the deck....
      So how do you do it...
    • Alik
      Correct. 2-4 layers with clean-up and different level of transparency.
    • Ramius41
      Or you could just give a transparency texture to the part you want transparent...and tell it how transparent you would like it.
  • Album:
    Member Album by Alik
    Alik
