12 m landing craft
Specmar.Aus
Specmar.Aus: 12 m landing craft
Posted by: Specmar.Aus - website: http://www.specmar.com.au
Specmar.Aus, Oct 13, 2008
    • Rating:
      5/5,
      ratrace2
      Nice work. . . . .8056 aluminium ??? maybe.....
    • ratrace2
      Do you tig on the strakes after you plate the hull, or what???
    • Specmar.Aus
      Hi Ratrac2
      Thanks for your comments: All the plate is 5083 marine grade with 6060 / 6061
      Extrusions.
      The boat in the photo was built in 2002 and the only welder I had back then was a WIA CDT pluse using 1.2 mm wire so the short answer is no we Mig welded the strakes to the shell later.
      These days we use a Delta pad bottom and no strakes gives better Nm per gallon at all speeds and is less work. Cheers Specmar.Aus
  • Album:
    Member Album by Specmar.Aus
    Specmar.Aus
