User Name
Password
  Home · Search · Register
Home » Member Galleries » Gerard DeRoy Photo Options
int_rieurArriere
Hull inside
more
more
Photo Details
Gerard DeRoy
users gallery
2 layers of vectra/epoxy have been applied.
With the Lindsay Lord concept it is important to do this in continous layer while there are no partition.
· Filesize: 32.5kb, 47.3kb ·
Additional Info
Keywords: Hull inside
Author
Thread
Willallison
November-6-2006 11:47pm
An interesting hullform. Can you explain your reasoning behind the way the 'keel' is higher than the turn of the bilge?
Will
Imaginocean Yacht Design
This user is offline
Click here to see this users profile Click here to Send this user a Private Message Visit Willallison's homepage! Find more posts by this user Visit this user's gallery
Gerard DeRoy
November-7-2006 9:29am
Hi Will,
Was wondering if anybody would notice it. Reasonning: Advantages: Form stability(low water ballast far outside) , lower draught. Potential disadvantage:Water flow separation(going from one hull to two). There is a flat bottom keel (20 feet long,
3 feet wide going from 6 to 28 inches height in the back) which will separate the flow anyway. Experimental motorsailor. very light, water ballasted + lead sheeting under the flat keel , junk rig, leeboards, L/B = 4.5. Design has not been exposed to professional designer yet, which I am not.
Thanks for the interest,
Gerard
Click here to see this users profile Click here to Send this user a Private Message Visit Gerard DeRoy's homepage! Find more posts by this user Visit this user's gallery
Willallison
November-8-2006 8:52pm
ok - but why not just have a flat bottom? I guess the curved surface is going to be a little stronger, but I don't recall seeing anything in Elements of Boat strength about the Lord process not being strong enough to incorporate flat panels
Will
Gerard DeRoy
November-9-2006 11:34am
Flat bottom? Agree that Lord process would be strong enough and this had no influence on my choice. I thought I was losing around 4 inches on draught and also on vertical position of water ballast. For construction : It is my first boat construction and I felt ill at ease with the required joints of a hard bilge design. For the design I felt that a hard bilge would be more difficult because of these developpable surfaces requirement. Stability at anchor? I have not done study on the subject but hope that those shoulders( on a light boat) will help to stop the rolling a bit.
Gerard
Powered by: vBulletin 3 Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2008 Boat Design Net
