Registered: November 2003 Location: Hamilton.New Zealand. Posts: 650
May-14-2005 6:32pm
Rating: 9
If you fitted CAM.A.PROPULSION to this craft you could have.A simpler drive with less mechanical power losses,lighter and stronger running gear which would be better supported,be more reliable for sustained high speeds and give better lateral control and better finer steering,and better speed control at all RPM ranges.Docking would be simpler and better.The propulsion would be much cheaper to build and maintain ect.,
------------------------------ tomkane
RANCHI OTTO Naval Architect
Registered: April 2005 Location: TRIESTE (ITALY) Posts: 1,026
May-14-2005 7:54pm
Thank you Tom Kane for the suggestion, only what is "CAM.A.PROPULSION" ?
Are you so kind to explain me ?
Thank you very much,
RANCHI Otto
May-14-2005 8:05pm
The craft has the following main data :
Hull shape > ASD (Arrow System Design)
Length hull > 14.60 m
Displacement F.L. > 20.0 t
Engines > 2 x 1150 bhp
Speed in trop. cond. (Kuwait) > 52.0 knots
tom kane Senior Member
May-14-2005 10:36pm
CAM.A.PROPULSION is a different approach to propulsion with many variations and is not just one design.My photo album has some images of some of the approaches that can be taken.If you read some of my posts they may be something of interest for you.
