Photo Details
Tanton Senior Member Registered: November 2003 Location: Newport RI Posts: 652 ![]() |
Interior.
The interior shown is one of many available and was designed for two people living aboard. Four sea berths are also provided. The aft cabin on the port side has a 54' wide berth and uses the chart table seat as a place to seat down. The chart table utilizes a 24' x 36" work surface with room to install navigation instruments. The port settee can be used as a sea berth and for dining seating with a flip up table section. Forward of the head is a separate sit down shower area that does double duty as a walk through to the forepeak which can be used for storage and a work bench. The L-shaped settee is surrounded by cabinets, lockers and book storage. The functional Galley has plenty of counterspace, two large sinks, propane stove and oven, fresh and salt water provisions and a well insulated ice-box. The foul weather gear locker separates the galley and the starboard quarter berth which is another good sea berth. A grate located at the bottom of the companionway provides drainage for wet gear. Other items of note are the 6'-3" headroom, 2-3" of foam insulation throughout and 80 gallon water capacity. the wood work is high grade birch with mahogany trim. Three opening hatches and 2 dorades provide both light and ventilation. Many of the interior items can be revised to reflect the individual preferences and use of the boat. Above text from the brochure. |
| · Date: September-8-2009 · Views: 1518 · Filesize: 89.7kb, 464.0kb · |
| Additional Info | |
| Keywords: Red Line 35. Cat-Sloop | |
