User Name
Password
  Home · Search · Register
Home » Design Galleries » Gallery of Student Design Work Previous image   Slide Show   Next image
2180Int_Moth1
International Moth
View Smaller Image
Photo Details
Olav
stud. arch. nav.
users gallery
Rendering of my current Moth design which will be built this winter with assistance of a fellow student. Note the 2nd centrecase (aft) where a hydrofoiled centreboard can be fitted. Building method is foam/carbon sandwich, estimated all-up weight (incl. rig, all fittings etc.) is slightly above 30kgs. For those who are interested in the software used: The hull has been designed with Hullform 6 whereas the rendering has been produced using SolidWorks and the use of the VRML-output feature of Hullform 9.
· Date: December-8-2003 · Views: 12568 · Filesize: 18.7kb, 89.4kb ·
Additional Info
Keywords: international moth
Print View
more
more
Author
Thread
Andy
December-9-2003 7:15pm
Looks good Olav. You might consider leaving out the 2nd centreboard case and save some weight unless you are convinced of the best location for it - see the current thread in the forum about foiler design (as im sure you already have). Then you can get rid of the conventional case when you switch to foils - or are you planning to use different foils and positions depending on conditions? Keep us up to date as you build, though!!! Andy
This user is offline
Click here to see this users profile Click here to Send this user a Private Message Visit Andy's homepage! Find more posts by this user Visit this user's gallery
Olav
stud. arch. nav.
December-10-2003 4:48am
Hi Andy,
Thanks for your comment!
I think your're perfectly right regarding the two centrecases. Yesterday I read the thread you mentioned, found a lot of interesting things posted there and came to a similar conclusion.
The boat is to have the Miller system (acknowledgements to both Rich Miller and Ian Ward by the way!) and I was a bit concerned about the required distance between the front foil and the centreboard (i.e. not too short for longtitudinal stability)so I guessed its value from the pics of Rich Miller's surfboard.
However, leaving out the 2nd case will save me likely trouble with the LCE...
Regards, Olav
All the best, Olav GER-1045 ____/)_/)/)___
Click here to see this users profile Click here to Send this user a Private Message Visit Olav's homepage! Find more posts by this user Visit this user's gallery
Powered by: vBulletin 3 Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2008 Boat Design Net
