Author
ratrace2
June-24-2008 11:18pm
Rating: 10
OK, Well.
First of all, I would rake the stem to about 30 degress and make it a straight line. The convex curviture of the stem makes the boat look too "stubby". Second, remove the first three portlights (looking from the stem to the stern) and remove all portlight below that line as well (below the spray line) . Third, take the flange off of the sheer line. Finally, the section above the first deck sallon need to terminate into the superstructure. You could leave it like it is if you put a door exiting to that area in the upper Salon Wall, just behind the windscreen(second tier). Change the Hull color to deep dark blue. Cut off that third deck behind the Radar.
After all that, I like it.
------------------------------ Who Said That?.....................
atomare
Registered: February 2008 Location: Netherlands Posts: 42
Dear RR2,
thanks for your comment... as for the portlights, from the outside I usually also would like to have none at all, while I am designing, but on the inside daylight and a view of the ocean are more than desirable and I think that also crew members deserve that (the lower portholes).
There is actually a door right in front of the ships name on the upper deck, (it doesn't show that well in the small resolution image...) leading into a staircase on the portside and directly into the upperdeck lounge/ wheelhouse on the starboard. The 'third deck' is actually a retractable sunroof, that can slide in and out. The two side beams run into the roofstructure, while the cloth is rolled up in the horizontal casing above the glass doors.
As for the color, every owner can choose his or her favorite tone .
ratrace2
Ya know, the more I look at it the more I like it.
