1.Grommet # 86480 2.Tube guide # 12570 3.Screw # 22370 4Grommet # 86490 5Screw # 22360 6Pump housing # 12430 Pump housing # 12395 7O-ring # 81250 8Cup & plate assy.# 12880 9Impeller # 89570 10O-ring # 82120 Seal # 86660 Key # 89590 Gasket # 33730 Oil seal # 86011 Screw # 22362 Bearing housing # 22720 O-ring # 81380 Shim .003 # 23590 / Shim .004 # 23580 / Shim .005 # 23510 Thrust washer # 21645 Thrust bearing # 16330 Drive shaft (L) # 22433 / Drive shaft (XL) # 22434 / Drive shaft (L) # 22435 Pin # 21139 Retainer # 28351 Lower drive shaft 22409 Pinion bearing # 22880 Forward gear set 22631 Reverse gear # 22632 Nut # 11190 Detente # 27720 Pin # 21138 Shaft # 27710 Thrust washer # 21644 Thrust bearing # 16310 Cross pin # 21135 Clutch dog # 22633 Spring # 11052 Prop shaft # 22416 Thrust bearing # 16300 Thrust washer # 21642 O-ring # 82370 Bearing # 22870 Bearing # 22860 Oil seal # 86030 Thrust washer # 22230 Spacer # 22250 Nut # 22150 Cotter pin # 22120 Anode # 12737 Screw # 22320 Screw & seal # 22300 Seal # 86640 Grommet # 86500 Screw # 22360 Gasket # 33020 O-ring # 45200 Screw # 22371 Draining screw # 21731 Gasket # 31171 Screw # 22374 Washer # 21674 Screw # 22366 Anode # 12766 Screw # 22368
