Old 06-26-2005, 04:58 PM
dhulv dhulv is offline
Rep: 10 Posts: 2
Wooden Ski Boat Restoration Questions
I just inherited a 16' wooden ski boat built by my father-in-law in the late 1960s. He built it using marine plywood for the hull, natural finish mahogany for the top side. The seams were sealed with fiberglass tape and resin. The hull was then painted with marine paint.
The hull has a few decades of wear and tear on it now, so I'm wondering what products are now available for filling and surfacing this wooden hull that he surely didn't have to work with then. I need to repair a couple of the fiberglass seams, along with lots of minor dings, nicks, scratches, etc. I would like to also be able to fill any construction low spots while I'm at it, and basically true up the lines a little. Are fillers available that will allow a little building up of areas to true up the sides? Or are you pretty limited to fairly thin layers?
I've had experience with woodworking (furniture) but am new to boats. Therefore any suggestions on restoration materials/techniques would be appreciated.
Old 06-27-2005, 09:39 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
In a word...Epoxy. You can thicken it as a filler, use it as a glue (also thickened), use it as a fairing compound, or laminate with it. You will need to protect it from UV with either paint or varnish (spar).
Steve
Old 06-27-2005, 11:03 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Yep, a few good versatile epoxies with appropriate hardeners and fillers will do just about everything you need. There's quite a range available and so you can tailor the mix to each particular task. Whether you need hard, sandable, clear, lightweight, whatever, there's a filler that you can blend with the epoxy to get the needed properties. West System's a popular choice; there are many others that all work well.
Old 06-28-2005, 01:31 PM
Rep: 10 Posts: 2
Thanks, sounds good. I took at look at the "West Systems" website. Looks like good stuff. I've also looked at the MAS products. Because of the age of the paint, should I be concerned with lead contamination when sanding (or was that never a component of colored marine paints)?
Old 06-28-2005, 09:59 PM
marshmat's Avatar
Lead's toxic, yes, and you need to wear protective gear when removing lead paint. You need to wear the same protective gear when sanding/stripping non-lead paints, so I would just err on the side of caution. A good cartridge-type filter mask, rubber-surround goggles, and a few different types of gloves are definitely worth the investment.
Inboard Ski Boat Molds for sale JustinW Boat Molds 10 10-05-2007 08:45 AM
Need HELP ON AQUIRED WOODEN BOAT JOHN P. Wooden Boat Building and Restoration 5 04-24-2005 12:43 PM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
Wooden Boat Manufacturing Boatbuilding 3 04-08-2002 12:32 PM
Wooden boat Boatbuilding 1 12-03-2001 01:30 AM
