Old 06-22-2004, 08:52 AM
yachtadina yachtadina is offline
Wooden masts & mast steps
I have just bought a yacht for (single-handed) offshore cruising. Unlike my previous yachts, this one has timber spars. I am used to having mast steps which enable me to go up any time.
I have never seen steps on timber spars which suggests a reason beyond asthetics. I would like some thoughts/advice on putting steps onto a timber spar. How much would I be risking by doing so?
A landlubber friend suggested metal straps to hold them in place. I wonder if anyone has come across this in use.
Any comments and suggestions would be welcome.
Old 06-22-2004, 09:00 AM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
You want to minimize penetrations (screws, bolts, etc.) into the mast because each screw hole is a possible location for moisture to enter the wood and cause rot. Normally access aloft is by ratlines on the shrouds or by bosun's chair.
On old vessels with mast hoops the crew used to use the hoops as ladder rungs, but I suspect that your boat is neither that large nor rigged with mast hoops.
Old 09-10-2004, 09:01 PM
Andy Reid
We've got a Tayana cruising yacht with Canadian oregan stick that has folding aluminium steps all the way up. They are great for reefspotting and rig checking when alone. I stripped the mast last year and checked out all fittings. The steps were held in by 3 woodscrews each and all were fine. For sure as the other correspondant says, you want to minimise potential water ingress so get into each hole with "evidure" or similar each time you remove any fittings and make sure your sika bedding is kept good on all fittings and you'll be good as gold.
Purests will tell you to varnish your mast so as to spot any damp spots asap but varnish is a lot of work compared to 2pot urethane! Your call.
Andy
Old 12-26-2004, 08:06 PM
Laurence Sive
Seeking Gordon Gregg
Hi
If this is Gordon Gregg please reply to my email sent to your email address. If no email has been received please advise your current email address so I can send the email again.
Thank you.
Laurence Sive (known by Gordon Phelps) email:laurence911@xtra.co.nz
Wooden Mast Construction wonderlost Wooden Boat Building and Restoration 7 06-18-2006 04:43 PM
Building a laminated wooden Mast Dominique Sailboats 14 06-02-2005 03:34 PM
Re-glueing wooden mast Aurora Wooden Boat Building and Restoration 18 04-20-2005 09:04 PM
bent wooden mast Simon Monard Sailboats 5 03-10-2005 04:08 PM
Canting mast casavecchia Sailboats 5 01-20-2005 12:15 PM
