Old 04-12-2011, 06:13 AM
Andy Andy is offline
Rep: 41 Posts: 185
Wooden Mast repair
Hi All,
on removing the spreaders on my spruce box-section mast this week in preparation for varnish I discovered a small area of rot under the spreader bracket. The mast seems to be solid at this point, hollow elsewhere. I have cleaned out the rot (about and inch deep) and chiselled a long, shallow 'V' into the mast (12-1 bevel on both sides) in preparation for epoxy gluing a matching graving piece. Problem is, I can't seem to get spar grade Sitka Spruce anywhere locally...
My question is, would Douglas Fir be an acceptible substitute or do I need to match the existing wood?
Andy
Old 04-12-2011, 08:05 AM
Rep: 3125 Posts: 9,408
Douglas fir is acceptable as are several of the pines, and spruces.
Old 04-12-2011, 08:18 AM
Rep: 41 Posts: 185
Thanks PAR, so it's ok to use a mix of wood species in this way?
Andy
Old 04-12-2011, 01:35 PM
You're not really mixing species, but rather fitting a filler piece. You could do the whole repair with just thickened epoxy, but a filler piece saves on goo. Now, if you replaced the whole side stave, to a rectangular mast with a different species, then you'd have some issues.
wooden hull repair GibsonGal Materials 0 09-11-2008 08:11 PM
Wooden Mast Repair MastSplit Boatbuilding 11 07-17-2008 12:26 PM
Old Wooden Mast Repair MastSplit Boat Design 2 07-03-2008 07:43 AM
Wooden Mast Repair MastSplit Wooden Boat Building and Restoration 11 11-14-2007 06:44 PM
Need Advice To Repair Wooden Boat klentz Wooden Boat Building and Restoration 9 12-25-2006 12:21 AM
