Old 07-09-2010, 08:55 AM
scott_n06's Avatar
scott_n06 scott_n06 is offline
Rep: 10 Posts: 18
Wood sealing questions?
Hello all,
I am thinking of building a mouse boat. I want something small and cheap that I can carry into smal ponds and lakes so it seems like a pretty good boat for a first timer. Anyway my question is, I work at an auto parts store so I can get a pretty good price on paint and other supplies. Would it work to coat the inside and outside of the plywood with fiberglass resin then paint over it with an acrylic enamel spray paint?
Thanks,
Scott
Old 07-09-2010, 10:23 AM
apex1
Assuming the boat will not sit in the water for more than a couple of hrs before it is hauled again, right?
In that case skimp on the resin (which most probably is just polyester anyway), and apply a few more layers of paint.
Touch up the paint when the surface got scratched and enjoy your time.
Regards
Richard
Old 07-09-2010, 09:51 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
The kind of resins typically available in auto supplies are polyester and at least for your type of construction, aren't of much value in terms of waterproofing.
You can tape the seams with either polyester or epoxy but as apex says, paint alone is completely adaquate and even desirable for entire panels of a boat that lives mostly out of the water. You save money, weight, and time using just paint.
Well painted boat hulls, if maintained by immediate touch-ups and (for instance) every-other-year recoatings will last almost indefinitely.
Nor should you be sold on the idea of Imron or Awlgrip, no matter what the discount. Get a gallon of one-part polyurethane and brush it on. Properly applied it will look like a spray job and will be quite hard.
Two-part paints are not really ideal for softer surfaces anyway. You need a paint that can flex enough to stay unbroken if banged. Hard paints are best for hard materials such as fiberglass. Hard paints fracture if stressed.
If you can find or tint a gallon of porch and deck enamal that gives you the right color, they can be very durable paints for boats, generally requiring no primer and costing a third of the cost of marine paint.
Porch and deck paints are reinforced with polyurethane so they are hard and retain gloss well just like marine paints.
Old 07-09-2010, 11:03 PM
scott_n06's Avatar
Rep: 10 Posts: 18
Thanks for in info. Are all porch paints the same or are some made of different bases. Such as water vs. oil based?
Im thinking of painting it white so porch paint will work pretty good Im sure they sell it in white.
Also, I was wondering if when doing stitch and glue construction all the directions say to use epoxy to bond the seams. What do they mean by "epoxy"?
Old 07-10-2010, 03:39 AM
apex1
They mean Epoxy!
That is a completely different animal than polyester resin. It is watertight (poly is not), much easier to apply, and it sticks perfect on wood (poly does not).
Raka for example is one brand, West another.
For stitch and glue you MUST use Epoxy there is no other (sensible) way.
Cannot cmment on the paint stuff, I donŽt know whats on the market in the US.
Regards
Richard
Old 07-10-2010, 07:15 AM
scott_n06's Avatar
Rep: 10 Posts: 18
I understand I MUST use epoxy Im not trying to go with something else, I guess I should have been more specific on my question. What Im asking is the epoxy they are talking about something specific to this type of construction and marine use? Im just trying to narrow my search.
Old 07-10-2010, 07:38 AM
missinginaction missinginaction is online now
Rep: 417 Posts: 336
There are numerous brands of general purpose epoxy resins suitable for boat buillding, take a look at the following and you will understand the various uses and advantages of epoxy resins. Be warned though, once you start using epoxy and become comfortable with it's application you will be using it for all kinds of repairs and improvements.......properly used it's a safe and very useful product.
http://www.systemthree.com/reslibrar...Epoxy_Book.pdf
MIA
Old 07-10-2010, 07:41 AM
apex1
No Scott, there is nothing special. You can well stay away from everything with a "marine" label on it. That would just triple the price. In fact the cheapest stuff you can find will be more than sufficient.
But what you need is a 100% solid Epoxy resin and a matching hardener. !!!
Lookup "Raka" epoxy and you will find products in a fair priced range which are quality wise top level. Use the cheapest they offer and just choose a hardener which fits your needs. (usually a slow hardener is more convenient for a novice than a fast one. It gives you more time to get your layup done, and allows you to do layer on layer in one go without letting the former layup cure completely)
Take care, there are some products called "Glassfiber resin" or even "glassfiber Epoxy" which are both not Epoxy, but polyester resins!
Make sure you paint all the epoxy layups properly to prevent UV degradation.
Regards
Richard
Old 07-10-2010, 07:50 AM
alan white's Avatar
I would only use an epoxy formulation specifically recommended for marine use. If the company doesn't say "for marine use" or something similar, don't use it on a boat.
It's that simple.
Old 07-10-2010, 08:03 AM
apex1
It's that simple.
We are talking a simple S&G skiff here Alan. And then just the seams. YouŽll have it hard to find any Epoxy resin (for laminating) which will not do that job perfect.
In fact I have never seen a single example insufficient for that purpose.
The recommended Raka btw. is for marine use.
Regards
Richard
Old 07-10-2010, 08:04 AM
scott_n06's Avatar
Rep: 10 Posts: 18
Ok thanks alot guys Ill look into all the info.
Thanks again,
Scott
Old 07-10-2010, 08:10 AM
apex1
Some helpful links:
http://bateau2.com/howto-index.php#general
http://www.westsystem.com/ss/use-guides/
http://www.newfound.com/
on the latter site download the "construction notes".
Old 07-10-2010, 03:29 PM
scott_n06's Avatar
Rep: 10 Posts: 18
Does anyone have any idea how much epoxy I would need for the one sheet skiff? http://www3.sympatico.ca/herbert.mcleod/skiff.htm
thanks
Old 07-10-2010, 07:04 PM
apex1
There should be a BOM to be found either on that website or in the plans. If not, ask here again, some have built similar designs. (sorry I have no clue how much that can come down, the smallest craft I ever built was about 20- 40 times the displacement you are building)
Regards
richard
Old 07-11-2010, 08:04 AM
scott_n06's Avatar
Rep: 10 Posts: 18
Regards
richard
I really figured the BOM would tell the ammount as well Apex, but all it says is
"5) Glue; tube of polyurethane construction adhesive (PL premium), plastic resin glue (Weldwood) or epoxy"
From looking at the plans I will have approx. 20ft of seams to seal.
Sealing wood? (followup on Mongo's post) thudpucker Wooden Boat Building and Restoration 9 09-03-2008 07:55 PM
sealing wood computeruler Boatbuilding 18 08-18-2008 11:22 PM
Wood questions bearwen Wooden Boat Building and Restoration 7 06-29-2006 08:10 PM
Sealing wood with oil Big Guy Wooden Boat Building and Restoration 27 01-10-2005 12:17 PM
Wood sealing help needed RobinFLINT Wooden Boat Building and Restoration 4 08-31-2004 08:16 AM
