Old 07-11-2010, 09:04 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Apex, epoxy comes in every kind of formula. some is in stick form, which is kneaded by hand to mix. Some is "five minute" epoxy. Some is epoxy for priming, some mixed with additives to thicken it. I recommended marine epoxy (for laminating) to simplify the answer.
Scott, you asked about how to choose a good porch and deck enamel. First, use oil based paint. Second, I've had good luck with all the major brands and I highly recommend Benjamin Moore for durability.
Old 07-11-2010, 12:48 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,359
When they say plastic resin glue by Weldwood they are referring to resorcinol unless I am mistaken. Epoxy is easier for the beginner. A very small boat won't require that much epoxy unless you are wasteful. Maybe 1 quart, no more than 2 depending on the design. Got any pictures?
Hoyt
Old 07-11-2010, 06:33 PM
scott_n06's Avatar
scott_n06 scott_n06 is offline
Rep: 10 Posts: 18
I havent started anything Im just trying to gather all the stuff I will need first so I dont have any pics, however there are quite a few pics at this site. http://www3.sympatico.ca/herbert.mcleod/skiff.htm
And in all reality I plant to eventually turn it into this, http://www.simplicityboats.com/minisharpie.html
Old 07-11-2010, 07:52 PM
hoytedow's Avatar
Resistor
Make a test piece using 1 ounce of epoxy to see how far it will go. If 1 ounce does 1 foot of seam, 1 quart should do 32 feet of seam.
Hoyt
Old 07-11-2010, 08:34 PM
scott_n06's Avatar
Rep: 10 Posts: 18
Thats a pretty good thanks
Old 07-12-2010, 10:37 AM
apex1
Make the calculation much easier:
in a good layup you come out with a 50 / 50% ratio of resin / glass. More likely 60% resin 40% glass in a S&G handlayup.
Now go measure the weight of your glass tape, and there you are! Add some 10% for primering the seams (ply) prior to glassing.
Regards
Richard
Sealing wood? (followup on Mongo's post) thudpucker Wooden Boat Building and Restoration 9 09-03-2008 07:55 PM
sealing wood computeruler Boatbuilding 18 08-18-2008 11:22 PM
Wood questions bearwen Wooden Boat Building and Restoration 7 06-29-2006 08:10 PM
Sealing wood with oil Big Guy Wooden Boat Building and Restoration 27 01-10-2005 12:17 PM
Wood sealing help needed RobinFLINT Wooden Boat Building and Restoration 4 08-31-2004 08:16 AM
