Old 04-29-2005, 05:10 PM
trimix trimix is offline
Rep: 10 Posts: 35
Wood sandwich
For a 50' racing sailer,my idea is to use the cold moulded wood laminate technique but I would like to insert in the laminate a balsa end grain core or PVC foam.
The aim is to decrease the weight of the hull.
Is someone know if this way to do have already been used.
Old 04-30-2005, 11:27 AM
Eric Sponberg's Avatar
Eric Sponberg Eric Sponberg is online now
Rep: 2447 Posts: 1,376
Yes, Bruce Schwab's Ocean Planet was built with wood skins and, I believe, a Core-Cell (SAN foam) core. She was built in 2001 at Schooner Creek Boatworks in Oregon.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 05-01-2005, 09:37 AM
chandler chandler is offline
Rep: 16 Posts: 378
I had the oportunity to meet Bruce Schwab at the Maine Boatbuilders show last month...pretty cool guy
Old 05-02-2005, 02:20 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Trimix,
Steve Rander at Schooner Creek Boatworks has built several other boats in addition to Ocean Planet with the same technique, he might give you a few tips if you ask nicely.
It's a proven method, in fact, the first boat-build I ever worked on was a veneer/balsa-core Peter Norlin designed quarter-tonner my Dad was building in the winter of 1973/74 called Accent. At the time, they thought ready-made balsa-core was much too expensive, so they cut their own, then installed it with one staple in each block....... At the time I was five years old and my sister four, we were each given a pair of pliers, then we went around and pulled out all the staples we could reach.
The boat went on to win the Quarter-ton cup that year in Malmö, Sweden, molds were taken and the boat was put in production.
Growing up in a boat yard was a unique experience, I thoroughly recommend it.
Yokebutt.
Old 05-03-2005, 06:54 PM
Rep: 16 Posts: 378
Besides it's obvious lightweight what exactly does balsa core do??
Old 05-04-2005, 02:23 AM
Boatbuilder
Rep: 15 Posts: 545
Chandler,
Have a look at DIAB's website for a primer on cores. (divinycell)
Yokebutt.
Old 05-04-2005, 07:17 PM
Rep: 16 Posts: 378
You have a website addy??
Old 05-04-2005, 08:47 PM
Boatbuilder
Rep: 15 Posts: 545
Google diab.
Y.
Sandwich wood core strenght TomE Materials 17 09-26-2005 11:39 PM
best low tox wood preservative lofting4fun Wooden Boat Building and Restoration 3 08-27-2005 03:33 PM
Use of wood as core in polyester jfblouin Materials 24 02-20-2005 09:38 AM
Strip Planking wood Friedrich Materials 9 12-03-2004 12:03 AM
Wood sealing help needed RobinFLINT Wooden Boat Building and Restoration 4 08-31-2004 09:16 AM
