Old 10-23-2005, 10:30 AM
Markallen Markallen is offline
Rep: 10 Posts: 2
Windward 15
New to this forum....building a Karl Stambaugh Windward 15 and have 2 questions, please.
Should I fasten the hull to the frames completely or should I use minimal fastenings and let the hull "flex" on the frames?
Where can I obtain a small quantity of Dynel fabric for use on the deck of this boat?
Thanks in advance,
Mark
Charleston, SC
Old 10-23-2005, 08:57 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Why is not that shown very clearly on the plans?
Old 10-25-2005, 01:58 AM
Rep: 2891 Posts: 8,792
Karl Stambaugh's designs are what he calls "glue and screw" and shouldn't be confused with stitch and glue methods. His work typically relies on solid fastening of the planking to the frames with some glue for good measure. You don't want the planking moving around on the frames at all. If not sure about fastener types or spacing, give him a call.
A search on the web for Dynel will yield many hits, where you can then find a supplier in your area. Fiberglas supply stores should be able to get some if it's not in stock.
Old 10-25-2005, 06:00 PM
Rep: 10 Posts: 2
Thanks for the input, guys!
Old 10-25-2005, 10:39 PM
Racoo Racoo is offline
Alluminum Only
Best Way
Black electrical tape works for me!
toe in??? capt'n ron Boat Design 10 08-03-2005 03:44 PM
15' jon boat Tim Dykes Boatbuilding 7 12-06-2004 03:26 PM
Slippery to windward? Red At Night. Sailboats 9 03-27-2004 03:52 AM
Windward performance? Guest Boat Design 22 10-14-2003 07:32 AM
15 dingy sailer? Brad Sailboats 0 10-09-2001 12:52 AM
