Old 11-22-2007, 03:32 AM
russ@riverland. russ@riverland. is offline
Rep: 10 Posts: 6
William Atkin Seabright Skiff
Looking for someone who might have built "NAIAD", a 28ft x 8'8" x 2' seabright skiff. I have acquired the plans and intend to strip plank the hull in lieu of lapstrake. The designer calls for Cedar planking on Oak frames with Oak keel and deadwood. I have a ready supply of French Oak but am concerned about the topside weight if I should plank the hull completely in Oak, plus of course sheave inside and out. I have enough Oregon to plank above the waterline if this is a better option, but want to have a fully polished hull if possible. Safety is the priority though! Anyway, hopefully someone out there may have built one and will be able to help me with end displacement etc?
Old 11-22-2007, 09:48 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
No answers to your questions but you might try the Yahoo group listed below...
http://www.atkinboatplans.com/
http://groups.yahoo.com/group/AtkinBoats/
Old 11-22-2007, 07:30 PM
Rep: 3125 Posts: 9,408
I would strongly suggest you pass your intended plans deviations through a qualified designer. Lapstrake planking is about the lightest form of traditional construction going, unless you get involved with composite builds (which aren't especially traditional). Trading this in for a build method that would likely double the hull shell weight (or more) isn't an easy thing to recommend without some study of the original plans.
You don't need a Naiad builder as much as you need a NA to review your ideas, substitutions and requirements. For what it's worth, the Atkins seabright model is one I'm very familiar with and a wonderful sea boat.
Tolman Seabright skiff almost finished ... kengrome Powerboats 2 10-15-2007 06:29 AM
How to design an outboard on an Atkin Seabright Skiff??? SalmonMan Boat Design 48 07-10-2007 05:38 AM
William Garden Designs dick stave Boat Design 22 05-24-2007 11:01 PM
Seabright Skiff Armac Boat Design 4 12-18-2004 11:27 PM
William Jackson's Gypsy Guest Sailboats 0 10-21-2003 08:55 PM
