Old 08-24-2009, 07:14 PM
huejass huejass is offline
What should I be looking for in a new boat plans?
I'd like to build a 7m ski/cruising boat, and I've noticed that I'm terribly picky.
I want a wooden runabout/classic style boat with a stern-drive engine. I've found a boat builder that has plans that are similar, but they're for a fiberglass or aluminum hull. He has offered to rework the plans to fit my request.
He says that his plans will come with:
The construction plans would include the approx. following detailed drawings;
- General arrangement (plan & profile)
- Hull lines & hydrostatics
- Hull offsets, gunwale offsets
- Hull & deck structure
- Structural sections & details
- Engine setup & details
- Windscreen details
- Fuel tank details
Is this all I need? or should I make sure it has _______.
All suggestions and help are appreciated!
Regards,
Hue Jass
PS: in case you guys are curious what I'm looking at. You can check it out here: http://www.maxwell-hall.com/portfolio.php?boatId=59
Last edited by huejass : 08-24-2009 at 07:15 PM. Reason: To make it clear what is included in the plans.
Old 08-24-2009, 09:30 PM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
Take a look at this. https://www.boatdesigns.com/products.asp?dept=845
another http://glen-l.com/designs/hankinson/biscayne.html
Old 08-25-2009, 01:00 AM
Rep: 2891 Posts: 8,798
If you're terribly picky, you'll probably need a semi custom or full custom set of plans. Unless you have considerable experience with this builder or he is a long established builder with the reputation to support it, I would be quite hesitant about having him convert a GRP or aluminum plan to wood.
As far as plan set detail, frankly it shouldn't concern you, unless you are building it. By this I mean plans are only as good as the crew following them. I have yards that have done designs of mine previously. Some I just need to supply a set of lines, maybe some profiles and a scantling list. Others I have to wet nurse through the process, which requires extensive and detailed plan sets.
In this same vain, I recently built one of my designs and other then some general measurements, I didn't have any plans. I sort of knew what I wanted and "winged" it.
Triple keeled boat plans/vs trimaran vs swath boat for stability and searworthiness blackdaisies Stability 4 09-28-2008 01:09 PM
does any one have plans for this boat? eehaney Sailboats 0 06-10-2007 11:17 PM
new boat plans tallow98 Powerboats 3 06-08-2007 07:13 AM
Need boat plans (please help) EMporto Boat Design 1 11-22-2004 07:25 PM
Boat Plans ? RolandZe Boat Design 4 04-29-2004 04:14 AM
