Old 10-04-2005, 07:04 AM
KMD KMD is offline
Rep: 10 Posts: 8
What kind of fiberglass/epoxy to use?
I have a 37' Chesapeake bay built. I am building a new deck for the boat, I built all the floor trusses and supports out of presure treated lumber. I am going to use 3/4 " Marine plywood for the deck material. I want to fiberglass the top of the deck but do not know which type of fiberglass matting to use. I do not know anything about fiberglass cloth/epoxy/resin/etc..... below was the method I was going to do this project in could I get some comments if I am doing this correctly?
The method I was going to use was to put some type of resin and cloth on all the edges of the plywood , then once the glass dried I was going to treat the bottom of the plywood with some type of wood preservative (Cupinal, or some other environmentally friendly treatment.) Next I will screw the plywood to the floor then glass the entire deck with some type of fiberglass and epoxy. This is a workboat so it doesnt have to be a yacht quality finish, I was going to paint the floor when I was done.
Old 10-05-2005, 04:00 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 511
Hi KMD,
I am posting a transcript of an article that was in Professional Boatbuilder magazine some years ago that I think will be helpful to you and maybe some others as well. See the attachments.
Best Wishes,
Gilbert
What kind of fiberglass/epoxy to use?-waynesdeck.jpg
Old 10-09-2005, 02:13 AM
boatbuilder.org boatbuilder.org is offline
Rep: 10 Posts: 54
Dynel makes a great abrasion resistant surface, and use MAS low viscosity resin and the no-blush slow or medium hardeners <http://www.boatbuilder.org/epoxy.htm>
---Joel---
(360)-790-0577
Old 10-10-2005, 06:21 PM
unhippy unhippy is offline
Rep: 10 Posts: 10
KMD,
Ditto on the MAS epoxy. I've worked with West and System 3 and I like the MAS better. Their medium hardener gives a relatively quick cure even in cooler temps. and produces little or no blush.
Some people would use polyester resin and chopped strand mat because it's cheaper than epoxy but be aware that it will delaminate eventually.
If you've gone through the trouble to use quality materials so far then it seems like a good idea to use a good quality epoxy resin and glass.
Good luck!
unhippy
SO WHAT? My dog still loves me!
Old 10-18-2005, 06:37 PM
chandler chandler is offline
Rep: 16 Posts: 378
I agree with boatbuilder and unhippy. MAS is easy to work with and doesn't smell too bad, dynel is good stuff, for non skid on a workboat, mix raw sugar rough sugar crystals in the top coat.
Old 10-21-2005, 12:22 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
We use the Marinepoxy and 6 oz. cloth for most of our decks - its cheaper than the name brand epoxies and works just as well for these type applications. Non-skid additive is very cheap and it will suspend in the paint of resin you use which gives better results than sugar, salt, sand, walnut shells, etc.....
Old 10-27-2005, 09:30 PM
drs3317 drs3317 is offline
Rep: 10 Posts: 47
JR-Shine,
Do you use more than one layer of 6oz on your decks? I'm now ready to glass the cockpit in my 31'. I have 3/4" MDO which will be epoxy coated first. Just wondering if I should use more than one layer of fiberglass for added protection? Also where do you get Marinepoxy?
Thanks,
Danny
Old 10-27-2005, 10:45 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
There really is no such thing as a marine epoxy. There are better quality epoxies. Used in boats, planes, cars, trains,etc.--www.oneoceankayaks.com has a rating of epoxies and why some work better.
Old 10-28-2005, 08:33 AM
SHINE
Rep: 50 Posts: 282
Originally Posted by drs3317
JR-Shine,
Thanks,
Danny
Marinepoxy is a brand we sell at boatbuildercentral.com. I would prefer to use one layer of 9 oz. instead of multiple layers of lighter cloth. Its less work and less chance of mistakes.
Joel
Old 10-28-2005, 03:43 PM
Rep: 16 Posts: 378
KMD
A couple of things...if it's not too late, avoid pressure treated lumber, it's very unstable new growth southern yellow pine, with the epoxy and glass deck if properly done shouldn't leak, spruce would be lighter and cheaper. You should really seal both sides and all edges of the ply with epoxy, skip the cuprinol.
Old 10-28-2005, 05:48 PM
I did not know the public could obtain Cuprinol any easier than pesticides, EPA?
Old 10-28-2005, 07:23 PM
Rep: 10 Posts: 10
I think Cuprinol has a new "environmentaly friendly" formula.
I still wouldn't recomend drinking it though.
unhippy
Old 10-28-2005, 10:40 PM
Deering Deering is offline
Rep: 14 Posts: 219
Concur with Chandler. Epoxy all sides. Keeps humidity variations in the air from causing swelling and shrinking of the plywood which leads to stresses on the attachments and delamination. Just epoxy, no glass required on the bottom unless you want to stiffen the deck.
Old 10-29-2005, 12:32 PM
Rep: 10 Posts: 10
AAAaah yes. The encapsulation doctrine! You are absolutely correct!
unhippy
Old 10-29-2005, 02:31 PM
Rep: 16 Posts: 378
Yes cuprinol comes in all kinds of user friendly shades these days..It's not the cuprinol our fathers used.
What kind of open sail boat is this, Spanker like? Sander Rave Sailboats 0 07-22-2005 06:35 AM
What kind of prop that make the most turbulence? howard_khoo Propulsion 1 03-20-2005 12:33 PM
Which is the most economical kind of small vessel? Guest Boat Design 40 11-24-2004 02:33 AM
what kind of sailboat is this boatyboat Boat Design 8 09-14-2004 08:01 PM
Stephen Wolfram's A New Kind of Science Jeff Open Discussion: All Things Boats & Boating 2 06-10-2002 07:29 AM
