Old 05-06-2006, 11:09 AM
kag65 kag65 is offline
Rep: 10 Posts: 9
What the Best 3D sketch modeling process?
Studio 3D sketch modeling is 3D brainstorming in real time. Very powerful tool for concept modeling. Real time morphing surface or point cloud works if have node to node connectivity. Together with 5 axis CNC make prototype dreams come true. The morphing video with changes took about one hour real time. Used this process it Ford PDC and milling full size mustang (s97). 3D Digital boundaries in design is knowing the process up front through the cnc machining of product. Don’t imagine the shape bend reality with style. Reverse engineering using Point cloud stl and surface data and CNC milling 5 axis requires High quality surface parameterization used to define tool path G & M code. I have milled the S97 mustang hood stl with ½ flat end mill tool running 9 mm step over. So it does work in the studio if you know the Process and have strong education and Background. Software does not make processes requirements do! So the question is. Why Not try new process?
Another Post Example Concept Car Morphing
http://www.millit5.com/Car9.html
KAG65
Chief CNC ENGINEER
http://www.millit5.com/index2.html
Old 05-06-2006, 04:44 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
If you're trying to advertise your shop, how about looking through the Directory on this site and adding a listing there?
Preliminary Sketch Willallison Option One 49 09-30-2004 07:17 PM
VRMesh 1.0 – a new style of sketch-based 3D modeling tool nicedays Software 0 08-13-2004 03:07 AM
simulate infusion process pdesign Software 1 06-02-2004 04:10 AM
the 1 hour sketch 8knots Option One 11 03-23-2002 08:52 PM
the 1 hour sketch 8knots Boat Design 11 03-23-2002 08:52 PM
